Inkremental Drehgeber
03.01.2013, 19:21
MavenD Offline
RE: Inkremental Drehgeber
Hi Gerd ,
This is my logic i have used in the pic below
07.01.2013, 09:00
MavenD Offline
Hi everyone ,
Can anyone tell me how to build the above logic in Labview ?
07.01.2013, 09:10 (Dieser Beitrag wurde zuletzt bearbeitet: 07.01.2013 09:33 von GerdW.)
Hi Maveen,
where's the counter output in your picture?
What is the meaning of "Counting selection"?
I hope I made no errors:
Edit: Is there a reason why you created a new user account?
09.01.2013, 10:34
MavenD Offline
Hi gerd,
thanks for ur reply.
counting selection decides where it is count up or down.
later i have to make a counter in labview to count up or down from this signal.
I forget the password of the previous one . sorry dats y i creeated a new one.
09.01.2013, 10:44
Hi Maveen,
you could always ask for resetting the password of your old account, no need to create multiple accounts...
Your logic has (atleast) a flaw:
What happens when the encoder is not moving/rotating? Will you still count up/down depending on "count selection"?
24.01.2013, 16:09
MavenD Offline
Hi Gerd ,
I am back after trying other tasks.
Can i make this algorithm in formula node will it be feasiable?
or will it take a lot of time .
can you help me?
24.01.2013, 16:30
Hi Maveen,
I'm not a friend of the formula node. Most always it's better/faster to use "real" G code instead...
