Communication via Profinet
06.09.2013, 12:23
Sun87 Offline
Hi all,
I am new to this forum and sorry I can't speak German. I have a question regarding to use Labview with Profinet. Since I searched a lot of information about Hilscher and Interbus, so I guess maybe some of you are also familiar with profinet and give me some help.
I have a device which previously worked with Interbus standard. Now the system is upgraded and the device has to be working with profinet standard. I am not quite familiar with profinet, but according to my knowledge, profinet has the same physical layer as normal ethernet and also uses TCP/IP protocol. Does that mean I can connect my Labview program with this device via normal TCP/IP connections? Is there any special toolbox that can be used for profinet?
Thank you so much for your help!
Best regards,
Sun87
Communication via Profinet - Sun87 - 06.09.2013 12:23
RE: Communication via Profinet - Y-P - 12.09.2013, 09:20
  Kommunikation mit einer SPS über Profinet Haarry09 1 8.545 08.06.2010 16:14
