Teil des FP als Bild ablegen
08.11.2007, 12:21
VDB Offline
2010-2011
RTFM ^_^
Front Panel:Get Image Method
Method of VI.
Returns an image of the front panel as a flattened pixmap. Use the Front Panel:Get Image Scaled method to return an image of the front panel and scale it proportionally according to the maximum width and height you wire to the method. If a front panel is not visible, LabVIEW does not update the values in the objects on the front panel. If you call a VI whose front panel is not visible and you use the Front Panel:Get Image method to create an image of the front panel, the image does not reflect any value changes that occurred when you ran the VI.
If you want the image to reflect value changes, make sure the front panel is open before any values change. If you do not want to display the front panel but want the image to reflect value changes, create a Property Node from any front panel terminal on the block diagram of the VI for which you want to create a front panel image.
You also can use the Append Front Panel Image to Report VI to create an image of a front panel and append it to a report.
VDB
Teil des FP als Bild ablegen - VDB - 08.11.2007 12:21
  Intensitätsgraph ziehen und ablegen Hubert R. 0 2.856 22.02.2017 15:17
Letzter Beitrag: Hubert R.
  nur einen Teil einer TDMS Datei lesen gottfried 1 4.565 06.02.2017 17:47
Letzter Beitrag: gottfried
  Listenfeld, ziehen, ablegen und löschen Hubert R. 3 5.545 10.01.2017 14:20
  nur Teil aus txt Datei einlesen hubem14 10 7.659 21.07.2016 09:45
Letzter Beitrag: hubem14
  Teil-Array-Ersetzen mit Offset beckmich 4 7.122 16.08.2011 15:00
Letzter Beitrag: beckmich
  Signal-teil löschen Amina 2 4.324 05.06.2011 21:54
Letzter Beitrag: Amina
