LabVIEW 5.0 auf Win 3.1
10.12.2004, 14:21
Dennis.Moser Offline
Administrator
Administrators
5.1 : 7.1 : 8.x : 20xx
hallo,
anbei ein auszug aus den SYSTEMVORAUSETZUNGEN:
Windows
LabVIEW for Windows is distributed on CD, which contains versions for Windows 95/98/NT. This CD also includes the complete instrument driver library that was available when LabVIEW 5.1 released.
The LabVIEW Online Tutorial default configuration requires the LabVIEW 5.1 distribution CD to be in your CD-ROM drive. If this configuration is not suitable for your needs, you can install the LabVIEW Online Tutorial files on your hard drive. You need approximately 40 MB of hard disk space to do this.
The LabVIEW Online Tutorial and LabVIEW Help files contain 256-color graphics. Your video driver, configured through Control Panels»Display, must be configured for 256 colors. Minimum requirements to view the tutorial are 800 × 600 pixel resolution and the Microsoft Video for Windows driver. For viewing Help files, National Instruments recommends that you configure your video driver for 256 colors with 800 × 600 pixel resolution.
Note (Windows NT 4.0) If your display is in 16-bit mode, you might want to change it to 256 or 24-bit color for better performance when viewing the LabVIEW Online Tutorial.
(Windows 95/98) LabVIEW 5.1 for Windows 95/98 runs on any system that supports Windows 95/98. National Instruments recommends 32 MB of RAM and a Pentium processor for this version to run effectively.
(Windows NT) LabVIEW 5.1 for Windows NT runs on Windows NT 4.0 Service Pack 3 or greater. National Instruments recommends 32 MB of RAM and a Pentium processor for this version to run effectively. DEC Alpha, MIPS, and PowerPC 80x86 emulators must emulate 80386 instructions to run LabVIEW.
Note On Windows systems, you need a minimum of 60 MB of disk storage space for the Base package or 85 MB for the Full Development System. You need a minimum of 16 MB of RAM.
Copyright 1994, 1999 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. LabVIEW is a registered trademark of National Instruments Corporation.
gruss dennis
LabVIEW 5.0 auf Win 3.1 - lars - 10.12.2004, 14:13
LabVIEW 5.0 auf Win 3.1 - Dennis.Moser - 10.12.2004, 14:16
LabVIEW 5.0 auf Win 3.1 - Dennis.Moser - 10.12.2004 14:21
LabVIEW 5.0 auf Win 3.1 - lars - 10.12.2004, 14:23
