LabVIEW DLL in C# verwenden
13.01.2009, 11:21
TSC Offline
LV 2018 SP1
Weitere erkenntnisse:
Zitat:Problem:
I've completed my program in LabVIEW and it runs without errors. However when I turn the program into an executable I get error 1043 "The property or method is not supported in this version of LabVIEW." I'm using the same version of the Run Time engine as the LabVIEW development environment in which I created my program. Why am I getting this version error?
Solution:
"Version" in this case refers to the Run Time engine versus the LabVIEW development environment. There are various property nodes and invoke nodes that are only available in the development environment. To find out if a property or method is supported in the Run Time engine open the detailed help for the property or method of interest. You'll see a chart at the bottom of the help document that lists various remarks about the node that resembles the following.
[Quelle: http://digital.ni.com/public.nsf/allkb/1E1...625731C006CCB5A]
Anscheinend kann ich das VI also so nicht lassen und muss mir was neues ausdenken. Schade.
LabVIEW DLL in C# verwenden - TSC - 12.01.2009, 17:20
LabVIEW DLL in C# verwenden - IchSelbst - 12.01.2009, 22:59
LabVIEW DLL in C# verwenden - TSC - 13.01.2009, 09:00
LabVIEW DLL in C# verwenden - IchSelbst - 13.01.2009, 09:28
LabVIEW DLL in C# verwenden - TSC - 13.01.2009, 11:17
LabVIEW DLL in C# verwenden - TSC - 13.01.2009 11:21
  dll vonLabVIEW in Matlab Simulink verwenden /LabVIEW -> Matlab XPC hans_p 0 5.244 10.12.2009 10:19
Letzter Beitrag: hans_p
  LabVIEW Dll in VB.NET verwenden Frank Grießbaum 3 6.334 04.10.2006 13:42
Letzter Beitrag: eg
