remote debug
13.03.2009, 18:48
Dennis.Moser Offline
Administrator
Administrators
5.1 : 7.1 : 8.x : 20xx
remote debug
Hallo Gottfried,
ich denke es liegt an einen gesperrten "dynamischen" Port siehe hier...
http://digital.ni.com/public.nsf/allkb/FED...62572B9007EA774
Gruß Dennis
Zitat:What is the Port Number Assigned for Remote Debugging in LabVIEW?
Primary Software: LabVIEW Development Systems>>Base Package
Primary Software Version: 8.2
Primary Software Fixed Version: N/A
Secondary Software: N/A
Problem:
What is the port number assigned for Remote Debugging in LabVIEW?
Solution:
Remote debugging does not use a specific port or range of ports. It asks the operating system to assign a port that is available at that time.
If you need to configure your firewall to allow remote debugging, one way to do this is to always allow the LabVIEW application to open whatever ports it needs to. For more information, please refer to the KnowledgeBase article linked below.
Note: You will also need to configure the firewall to allow access to port 3580, which is for the NI Service Locator. Remote debugging uses the NI Service Locator to learn the actual port the debuggable application is using. This is necessary since that application chooses a dynamic port and the client needs to figure out that port at run time. A link to more information about the NI Service Locator is provided below.
remote debug - gottfried - 26.02.2009, 14:38
remote debug - gottfried - 11.03.2009, 15:54
remote debug - TSC - 11.03.2009, 16:01
remote debug - rolfk - 12.03.2009, 22:01
remote debug - gottfried - 13.03.2009, 17:09
remote debug - Dennis.Moser - 13.03.2009 18:48
remote debug - gottfried - 16.03.2009, 11:12
  Wechsel zum Blockdiagramm bei Remote debug GT123 5 6.448 25.05.2011 05:23
Letzter Beitrag: GT123
  exe mit Remote unterstützung.... John Doh 2 4.392 21.06.2008 00:17
Letzter Beitrag: srokajo
  Runtime Version und remote zugriff? feinwerk 2 5.176 30.09.2005 06:52
Letzter Beitrag: feinwerk
