Manipulieren des Autoscales bei XY-Graphen
29.03.2006, 21:45
Irene He Offline
Ich hoffe dass ich deinen Probleme richtig versteht.
You don't need autoscale, instead you can create the graph property node->Y Scale->Range->Maximum and Minimum, by change these two property values of graph, you can set your graph scale to any range. Because as you said each time your measurement values change, so you need to find out the maximum value of your measurement data, then multiple with 110%, and this value you can use to set the graph maximum scale. Same thing with the minimum scale of graph.
I hope this will help.
Irene
http://www.hytekautomation.com
LabVIEW camera and video toolkit provider
Manipulieren des Autoscales bei XY-Graphen - Irene He - 29.03.2006 21:45
  autoscale manipulieren fani88 3 4.626 08.02.2013 12:46
Letzter Beitrag: fani88
  Array manipulieren Klausi 7 5.582 13.07.2009 20:40
Letzter Beitrag: Klausi
  History Chart manipulieren gottfried 3 4.570 13.05.2008 20:57
Letzter Beitrag: IchSelbst
  2 Graphen mit unterschiedlichem dt in einen Graphen unaimed 8 11.340 14.03.2005 14:45
Letzter Beitrag: unaimed
