Refnum error
27.08.2012, 08:49
mathew086 Offline
Refnum error
Hello
I have Main VI that contain a cluster of 13 elements (string)
I want to connect this cluster as an input to a subVI. See Attachment
But then there is this string --> String Refnum error. Can anyone please help
Thanks
11.0 .vi  MainVI.vi (Größe: 8,24 KB / Downloads: 172)
11.0 .vi  SubVI.vi (Größe: 21,78 KB / Downloads: 190)
27.08.2012, 09:56
A.Berndsen Offline
724xx
RE: Refnum error
Hi Mathew,
don't connect a cluster of strings to a cluster of string refs.
That doesn't works.
Have a look at my example.
8.5 .vi  main_string.vi (Größe: 9,68 KB / Downloads: 236)
8.5 .vi  sub_string.vi (Größe: 8,13 KB / Downloads: 215)
8.5 .ctl  cluster_def.ctl (Größe: 5,46 KB / Downloads: 218)
Regards
Andreas
Geht nicht, gibts nicht!
27.08.2012, 09:58 (Dieser Beitrag wurde zuletzt bearbeitet: 27.08.2012 10:01 von GerdW.)
RE: Refnum error
Hi mathew,
you have connected two different clusters. That will never work...
In the main VI you use a cluster with several strings, whereas the subVI expects a cluster of references (of different types...)! You have to create a suitable cluster in the mainVI...
P.S.:
Did you know there's an English-speaking LabVIEW forum at NI.com?
Edited:
Yes, you knew that forum already, as can be seen here! Please note: when creating double posts in several forums it's always a good idea to mention that by providing links to other related posts...
  typedef refnum's to string and back GT123 8 5.711 09.09.2016 14:25
Letzter Beitrag: GT123
  SubVi - Referenz Refnum vescon 2 5.271 01.10.2014 08:44
Letzter Beitrag: vescon
  Fehler 4801 "invalid task refnum" banman 5 6.615 24.02.2011 09:31
Letzter Beitrag: banman
  Refnum für Cluster erstellen? NafeZ 6 9.218 12.10.2009 17:26
Letzter Beitrag: bikobeko
  Stringwert in Refnum->Array->Cluster->String Indicator.JPG GT123 2 4.823 22.07.2009 08:43
  Refnum nach String oder nach int32 t4b-1re-2 4 6.821 27.05.2008 16:15
