How do i change the item in the drop down list, and furthermore update the constant
23.04.2014, 13:30
mexaviesta Offline
hello guys,
I have a drop down list Control that is full of items. I would like to change the lables on these items at runtime, as i knew, i should use the Ring but not Enum, because we can't change values of enum at runtime.
Furthermore i want to creat a Constant from this Control (drop down list ) on the block diagram, but if i edit the item list of the Ring control, LabVIEW does not automatically update the constant to which it is linked.
how can I solve it?
Thx and Best regards
Di
23.04.2014, 13:50 (Dieser Beitrag wurde zuletzt bearbeitet: 23.04.2014 14:07 von jg.)
RE: How do i change the item in the drop down list, and furthermore update the constant
Offtopic2
In accordance with the rules of this community tell us about your crossposts.
Greetings, Jens
23.04.2014, 13:53
Hi Di,
already answered in your crosspost in the NI LabVIEW forum…
24.04.2014, 07:08
Und wenn Du schon "cross-postest", dann schreib' doch wenigstens in Deutsch, wenn Du schon aus Deutschland kommst.
  Menüpunkt in Ring Constant auswählen creo_123 3 9.530 24.05.2024 07:05
Letzter Beitrag: creo_123
  Datei über Drag & Drop in andere Anwendung (kein LabVIEW) verschieben ahebauer 2 4.439 29.03.2017 08:41
Letzter Beitrag: ahebauer
  Drop-Down Menü zum (de)aktivieren von GUI-Elementen Atlaspremier 11 12.529 12.07.2016 12:10
  Update LV2010 auf 2014 Strings Dommas 4 4.764 10.07.2015 10:46
Letzter Beitrag: Dommas
  Tabelle/Listbox mit Drop Down eg 8 13.024 28.03.2015 16:32
Letzter Beitrag: hansi9990
  Nach Update auf 2013 kein FPGA mehr skar 10 10.684 15.07.2014 15:13
