Schnelligkeit VISA Write/Read
23.07.2012, 22:47
Bowi0L Offline
RE: Schnelligkeit VISA Write/Read
Habe das Problem gelöst nach langem Suchen:
... To fix things, go to the "Device Manager -> Ports" and select the USB Serial Port corresponding to your Serial Converter. Right Click and select "Properties". When the Properties window comes up, select "Port Settings" and then select "Advanced...". Under "BM Options" there is a "Latency Timer". I changed mine from 16 msec to 1 msec and the delay problem went away and the data comes over perfectly. Hope this helps other frustrated users...
mfg
Thomas
Schnelligkeit VISA Write/Read - Bowi0L - 23.07.2012, 21:54
RE: Schnelligkeit VISA Write/Read - Bowi0L - 23.07.2012 22:47
  VISA Read und Bytes at Port tanka 9 13.868 28.08.2019 08:10
  Komische Zeitverzögerung bei VISA write Parallelport dehmelp 8 6.298 20.07.2017 12:29
Letzter Beitrag: dehmelp
  VISA Read Fehler 1073807302 Stefan1101 4 7.690 29.08.2016 10:13
Letzter Beitrag: Stefan1101
  Serial Port mit Continuous Serial Read Write Hoang Nguyen 2 7.773 15.04.2016 10:35
Letzter Beitrag: Hoang Nguyen
  VISA Read mit Keithley 6487 dauert lange jusaca 3 5.557 28.01.2016 11:12
Letzter Beitrag: jusaca
  1x COM-Port, 2 x Write & 2x Read Jann 19 15.217 10.12.2015 14:17
