Timed acquisition
12.05.2018, 20:44
Labview_pr Offline
2017
RE: Timed acquisition
Hi @GerdW,
Thank you for your reply.
If I get it well, do you mean a Daqmx Task that generates a digital edge for the acquisition? ( Denknach)
In my case, the digital event source is an external machine (via NI9361).
Maybe I need to set for the acquisition channel to read a specific amount of samples as you said (Please could you check the capture below).
for the 2nd option, do you mean that I need to read the first saples and then delete them ?! and read the next samples ?
Many thanks again Smile
Labview_pr
Timed acquisition - Labview_pr - 12.05.2018, 12:17
RE: Timed acquisition - GerdW - 12.05.2018, 14:45
RE: Timed acquisition - Labview_pr - 12.05.2018 20:44
RE: Timed acquisition - GerdW - 13.05.2018, 18:36
RE: Timed acquisition - Labview_pr - 14.05.2018, 20:30
RE: Timed acquisition - GerdW - 14.05.2018, 20:51
RE: Timed acquisition - Labview_pr - 14.05.2018, 21:42
RE: Timed acquisition - jg - 15.05.2018, 09:46
RE: Timed acquisition - GerdW - 15.05.2018, 10:07
RE: Timed acquisition - Labview_pr - 24.05.2018, 10:23
  Acquisition mode stephan480 1 3.025 06.08.2019 16:23
  Hardware timed serial communication JATler 1 4.061 10.10.2018 13:55
Letzter Beitrag: JATler
  IMAQ Kamera Attribute während Acquisition ändern coolshaguar 1 5.865 13.05.2009 13:19
Letzter Beitrag: BNT
  2 Timed Loops gleichzeitig laufen lassen Darkwolf359 1 4.316 04.05.2007 12:05
Letzter Beitrag: Darkwolf359
  Synchrone Hardware-timed Messung pitsty 0 3.366 24.01.2007 12:38
Letzter Beitrag: pitsty
  PCI-6229 vs. Timed Loop Solaar 1 4.055 07.03.2006 11:14
Letzter Beitrag: cb
