Help-Datei - nur absolute Pfadangaben möglich?
07.12.2006, 15:38
VDB Offline
2010-2011
Allgemein kannst du das VI "Control Online Help" (Controls a compiled help file by displaying the table of contents, jumping to a specific topic in the file, or closing the help file. You can create a compiled help file and use this function to link from a VI to the help file. You also can use this function to display an HTML file in the default browser. ) benutzen.
Oder, VI-spezifisch die VI-Properties "Help.Path" (Path or symbolic path to an HTML file (.htm or .html) or compiled help file (.chm or .hlp) to which the VI is linked. If the path is to a compiled help file, use the Document Tag property to determine the specific topic in that help file.) und "Help.Tag" (Index keyword or HTML filename for a topic in the compiled help file to which the VI is linked. Use this property only when Document Path is a path to a compiled help file (.chm or .hlp).
For .chm files, this property can be an HTML filename or index keyword. For .hlp files, this property can be an index keyword.)
Gruß,
VDB
Help-Datei - nur absolute Pfadangaben möglich? - VDB - 07.12.2006 15:38
  absolute Feuchte berechnen malle 9 10.192 07.03.2011 16:57
Letzter Beitrag: Kiesch
  Absolute Zeitachse in Signalverlaufsdiagramm jojo 9 19.579 10.07.2009 19:47
Letzter Beitrag: ImExPorty
  Absolute Pfade zur Library fidel 3 4.074 23.11.2006 07:54
Letzter Beitrag: fidel
  Absolute Anfängerfrage über Numeric Controls/Indicators Joe 4 7.892 11.10.2004 14:11
Letzter Beitrag: Joe
