generqte a PWM signal with LabVIEW using digitals outputs
14.03.2006, 18:26
foxone Offline
ok, I have installed the last version of NI-DAQmx but it doesn't work neither. I don't understand, I can communicate with the 6070E card using the Measurement & Automation's Test panel without any problem. But it doesn't work with Labiew. I tried to configure it with DAQ assistant but I always received the same message "No supported devices found". You have to know that I use a remote system, with PXI chassis. I attached a screenshot of my MAX page, maybe you could see where I have done a mistake.
generqte a PWM signal with LabVIEW using digitals outputs - foxone - 14.03.2006 18:26
  Wie lese ich ein TTL-Signal richtig in LabView ein? aet 3 7.187 25.09.2012 15:39
Letzter Beitrag: aet
  mehrere Inputs und Outputs USB-6221 kob 1 4.371 18.07.2012 19:28
  Digitale Outputs des USB DAQ 6212 zudy 9 8.375 28.07.2011 15:54
Letzter Beitrag: zudy
  SPI Signal mittels LabVIEW Sandisk 20 19.229 18.01.2011 12:43
Letzter Beitrag: Sandisk
  Zwei DAQmx Channels zur Erzeugung zweier Analog Outputs zur Steuerung eines galvano XY-Scanners RiSo1985 18 16.775 22.01.2010 11:02
  Analog Signal und Counter Signal erfassen fiedl04 0 6.419 29.10.2009 11:58
Letzter Beitrag: fiedl04
