NI-XNET Problem mit NI VeriStand
24.04.2014, 10:16
Luk-Labviewforum Offline
VeriStand 2011 SP1
Sonstige
Hello
I have a VeriStand-Project (VSP) created with my Laptop-Host (LTH) which works with my PXI, while
deploying it from my LTH. Then I have installed the whole NI enviroment for PXI and VeriStand use on a
industrial PC (iPC). I have tried to deploy my VSP from the iPC to the PXI but the following error
message arose on my iPC:
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details: Error -1074384569 occurred at Project Window.lvlib:Project Window.vi >> Project
Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI-XNET: (Hex 0xBFF63147) The database information on the real-time system has been created with an
older NI-XNET version. This version is no longer supported. To correct this error, re-deploy your
database to the real-time system. ========================= NI VeriStand: NI VeriStand
Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI
VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize
Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi
* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * • Unloading System
Definition file... • Connection with target Controller has been lost.
The software versions of the NI products (MAX/My System/Software) between my LTH and the iPC are
almost the same. The only differences are:
1. LabView Run-Time 2009 SP1 (64-bit); is installed on LTH but missing on iPC
2. LabView Run-Time 2012 f3; is installed on LTH but missing on iPC
3. NI-DAQmx ADE Support 9.3.5; something strage on the LTH, because normally I am using NI-DAQmx 9.5.5
and all other DAQmx products on my LTH are 9.5.5. That means NI-DAQmx Device Driver 9.5.5 and NI-DAQmx
Configuration 9.5.5.. On the iPC side all three products are 9.5.5.. That means NI-DAQmx ADE Support
9.5.5, NI-DAQmx Device Driver 9.5.5 and NI-DAQmx Configuration 9.5.5..
4. Traditional NI-DAQ 7.4.4; The iPC has this SW installed. On the LTH this SW is missing.
In order to fix this problem I have formatted my PXI and I have installed the following SW from the
iPC:
1. LabVIEW Real-Time 11.0.1
2. NI-488.2 RT 3.0.0
3. NI_CAN 2.7.3
Unfortunately the above stated problem arose.
What can I do to fix this problem?
I found a hint on http://www.labviewforum.de/Thread-XNET-C...hversuche.
There it is written to deploy the dbc file againt.
If this is a good hint, so how do I deploy a dbc file?
I would feel very pleased if somebody could help me! :-)
Best regards
Lukas Nowak
  Xnet auf cRIO: DBC deployen nicht funktioniert Felix777 14 30.150 18.10.2017 06:09
Letzter Beitrag: Felix777
  XNET-Module auf cRIO jg 5 16.561 25.08.2017 10:16
  CANopen und XNET gfzk 16 50.688 21.04.2017 12:36
  XNET Create Session Error hoal 0 15.398 24.02.2016 14:06
Letzter Beitrag: hoal
