configure digital output regeneration with 6533
21.11.2014, 12:54
rcatxi2 Offline
Hello!
I want to continuous write a digital signal with the 6533 (PCI-DIO-32HS). This digital signal is generate from a finite pattern of 0 and 1 read from a txt file. The user could choose the sample rate and if the sequence will repeat continuously or only once.
1) I tried already with the “Write Property Node” in a while loop with a write function, but I can´t achieve it…The combination of this node with the DAQmx functions: write, start task, etc. that I did is not working.
Which functions should I use (write, start task, node, etc.) and in which order?
Which functions have to be in the while loop?
How should I configure the Write Property Node?
2) I tried also with the continuous sample mode from the DAQmx Timing and a continuous signal is generated. But how can I control to stop the task?
Because with this option I use the DAQmx Wait until done and I have this error -200560
Which option is better or should I do another?
Thank you!
10.0 .vi  leer_escri_tx_binario.vi (Größe: 39 KB / Downloads: 250)
21.11.2014, 15:59
RE: configure digital output regeneration with 6533
Offtopic2
Next time please tell everybody about your Cross-Posting:
http://www.labviewportal.ru/viewtopic.php?f=80&t=7598
Regards, Jens
  kontinuierliches Schreiben mit Regeneration Ch.Mueller 2 3.528 21.10.2021 07:07
Letzter Beitrag: Ch.Mueller
  Analog Output: hardware getaktet Output gleichzeitig mit on demand output kwakz 5 5.485 05.03.2021 10:04
  TDMS mit "Configure Logging" aber keine Index-Dateien? gottfried 2 4.594 21.06.2018 13:32
Letzter Beitrag: gottfried
  Verständnisfrage zu Schleifendauer bei Modus "Do not allow regeneration" BodenseeBike 6 6.109 24.02.2017 10:13
  NI PCI 6533 DIO-32HS I2C Ali 3 4.955 16.12.2010 16:48
Letzter Beitrag: Ali
  PCI 6533 DIO-32HS Datenerfassungskarte Ali 5 6.526 24.11.2010 23:56
