LabVIEW version
27.05.2009, 12:48
spring
Unregistered
LabVIEW version
I am new in this forum and so is my experience for LabVIEW. Now, I am designing a discrete PID control for temperature of a certain object in order to yield a constant temperature. This object is a TEC-cooler (Thermal Electrical). I think most times I might require functions for "control design and simulation". What I have now is Version 8.2, but I realize that it does not include the full package for discrete PID control. So I decided to install 8.5 or 8.6, since I saw some examples for this, which mostly use 8.5 or 8.6 for designing.
It would be an honour for me to get an idea which version and extra modules would be suitable for my task.
Furthermore I am searching for suitable literature. Eventhough I watched various books already, I haven't found specific examples for designing a discrete PID control? I am just learning German, but those technical terms I can better understand in English.
I would appreciate you also reply me in English. Thank you very much.Smile
Freundliche Grüße,
spring
27.05.2009, 12:50
LabVIEW version
Das hört sich verdammt nach Crosspost an!
Wenn Du schon woanders postest, dann erwähne das bitte und schreib' wenigstens hier auf Deutsch!
27.05.2009, 16:00
LabVIEW version
PID-Toolkit:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1394
I don't think, that you need the NI LabVIEW Control Design and Simulation Module
http://sine.ni.com/nips/cds/view/p/lang/en/nid/206895
27.05.2009, 18:48
spring
Unregistered
LabVIEW version
Well, thanks a lot for your kind reply. But for design discrete PID control, which is better between 8.5 and 8.6?Huh
27.05.2009, 19:56
LabVIEW version
Kenne mich mit diesem Thema (PID) nicht sonderlich aus. Aber es dürfte relativ egal sein, ob du nun 8.2 / 8.5 oder 8.6 verwendest.
09.06.2009, 20:06 (Dieser Beitrag wurde zuletzt bearbeitet: 09.06.2009 20:12 von jg.)
spring
Unregistered
LabVIEW version
Hi, thank you for every one' answers. I already have 8.6. If you have advice for book which teachs how to use LabVIEW to design discrete control, please give me some idea. Thanks!
Gruß, spring
09.06.2009, 20:28
LabVIEW version
Dann bitte Profil_ergaenzen. Danke.
' schrieb:I already have 8.6.
  llb Version zu alt (LV5), Bitte um speichern für neuere Version Peter04 3 6.888 30.01.2012 16:54
Letzter Beitrag: Peter04
  Labview-Version von VI ermitteln joerg030284 6 9.568 10.05.2011 13:32
Letzter Beitrag: joerg030284
  LabVIEW englische Version - Hilfedatei mit Dt. Hilfedatei ersetzen? STG 1 3.849 19.06.2009 16:32
Letzter Beitrag: TSC
  LabVIEW-Studenten-Version auf Buch hellboy 2 6.622 12.06.2009 13:59
Letzter Beitrag: hellboy
  LabVIEW Version runterspeichern scarlettay 4 5.139 17.11.2008 14:30
  ältere LabVIEW-Version C.Jung 4 5.733 16.01.2007 11:03
Letzter Beitrag: C.Jung
